Battery percentage always says 0%
I have problem with my camera. The battery is charged. But in app I always see 0% battery. I put battery from other cameras and it’s the same 0%, but in other cameras it shows reals % of battery
I am having the same problem, my battery never appears to be charging in the portal, and now is down to 15% I am waiting to see if it stops working when it reaches 0. It maybe like your ready 0% but inaccurate?? So waiting now, will post when I reach 0. Something is wrong but trying to find out what that is isn't easy. Problem after problem with these cameras!
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Have you tried to remove & re-install the Arlo app?
What version of the App are you using & what Device/Model/OS are you using?
What Device/Model/OS is this?
Can you upgrade to iOS 13.3 & test again. I have the same phone & can not replicate the issue. I would suggest contacting customer support regarding this issue since this error is following the camera. I have provided the link here for you - Arlo Tech Support
Since the last upgrade I have no percentage showing against any of the cameras on the Devices tab. I click on the green cog/sun to the right of a camera, go down and click on Device Info, then click on the Back (top left of screen) and it will take you to a Settings page and should have Battery and the percentage next to it.
What version of iOS are you using as well as Arlo app?
The latest Arlo app version is 2.13
Hello,
I am using 2.13_27035.
The battery percentage used to show under each camera in the Devices tab, however now it doesn't. Now I have to do the steps I outlined in the previous message in order to see them.
I thought it would be happening to everyone. Obviously not??
Amy.
