Battery Drain On Pro 2 Is Draining Fast
Hey All, I seem to be running into an issue with one of my camera's. I recently charged both cameras at the same time however the camera that is at the rear of my house is already down to 10% charge whilst the one at the front which is activated more is currently at 60%. Is there any reasons that one camera would loose its charge so quickly over another one ? -Paul
It may be a display issue. Try rebooting the base. Also, reinsert the batteries to reset the cameras.
How do you reset the base. I am having the same sort of thing with one of my Arlo cameras as well. Is it just tyrning off the base and back on. That is an easy task. Just cerious .
@jguerdat I tried resetting the base and removing the battery from the camera. I also disconnected the camera from my setup and re-synced it. However the issue remains and the camera will only stay charged for about a week before it tells me that the camera is tired.
A reset is NOT rebooting the base or turning the power off and back on. A reset is done by removing all devices from Settings, My Devices and maybe holding the reset button until the LEDs flash amber.
Any updates? I am experiencing the same issue
Hi @loulou3019
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Have you taken a camera closer to the base to see if the issue improves? That would help prove whether distance, blockage or interference is the issue.
Mine was currently dead due to battery drain.
I'm currently re-charging it now and I will keep you updated as to how long it lasts.
Things I've tried so far...
* Removed battery
* Charged battery
* Deleted camera from my set-up and then re-synced it.
I can't move the camera any closer to the base as both are in places where they need / have to be.
OK something is certainly wrong with either this camera or the battery !
* I charged the unit overnight to ensure it was at 100%
* I then used "Remove Device" to remove the camera from my setup.
* I then re-synced the camera and placed it back outside.
* After the 1st night it lost just over 10% of charge.
The unit has not lasted a full week and its already showing as "needs charging".
How do I return this ? Its far too late for me to return to Amazon, but its still less than a year old.
I’ve contacted tech support & now they’re basically saying I need to upgrade to a router with channels & that this will prevent the batteries from draining...which sounds crazy. So i have to spend more money in order for a $600+ system that guarantees 6month battery life to work properly?? Also, not to mention, this router channel thing isn’t mentioned in the setup or book. This doesn’t make sense, I think the issue lies in Arlo’s firmware smh
Changing the channels of your router will make no difference either. Its the usual.. lets blame another device before we blame our own.
I also got told that it was a router issue and I should try to move my router closer to the camera which is also a load of rubbish.
Hi @loulou3019
Have you tried to remove the camera from settings > my devices > re-add and test again?
@loulou3019 wrote:
Everyone seems to be having this issue....
Not here.
I have noticed no change since the latest round up updates.
The only camera that seems to drain more quickly than I'd expect is one of my Ultras.
Just another user
