I cannot connect arlo pro2 camera to basestation. My problem started when I removed my basestation from Arlo app and reconnected it again. Afterwards I couldn't connect the cameras to basestation. I think I should have removed the cameras from the app before I removed the basestation? Maybe that's the problem. I've tried to reset the cameras by holding the sync bottom for 15 seconds, but it doesn't work. Can anyone help?.
Message 1 of 3
866
Thanks for your reply. I realized I had made a mistake during setup. I chose the wrong camera type.
thanks again, though.
Message 3 of 3
799
FIrst, remove the camera from your account if you haven't done so already. Then try the manual sync method - briefly pressing sync on the base, and then briefly pressing the sync button on the camera. The camera should be about 3 feet (1 m) from the base.
Message 2 of 3
862
Message 3 of 3
800
