  • 2 Replies
  • 872 Views
BarbCue
I cannot connect arlo pro2 camera to basestation. My problem started when I removed my basestation from Arlo app and reconnected it again. Afterwards I couldn't connect the cameras to basestation. I think I should have removed the cameras from the app before I removed the basestation? Maybe that's the problem. I've tried to reset the cameras by holding the sync bottom for 15 seconds, but it doesn't work. Can anyone help?.
BarbCue
Thanks for your reply. I realized I had made a mistake during setup. I chose the wrong camera type.
thanks again, though.
FIrst, remove the camera from your account if you haven't done so already. Then try the manual sync method - briefly pressing sync on the base, and then briefly pressing the sync button on the camera. The camera should be about 3 feet (1 m) from the base.
BarbCue
  • 2 Replies
  • 873 Views
