Base unit cannot connect to router. Shows solid blue but shows blinking amber?
Cannot connect base unit to router (Netgear MR1100). The light turns solid blue for awhile and then starts blinking amber. Neither the app for the router or app for Arlo will discover device. Any ideas?
Start by rebooting the router and base, in that order.
Tried rebooting both in proper order without success. The router app that works best with my MR1100 is “NETGEAR Mobile Utilities.” The menu page has an ARLO link. Clicking on that link brings up a page titled ARLO with an “Enable” switch and also “Sync Camera” and “My Arlo” links. I switched on “Enable” and everything connected properly.
So simple. I need a “Dummies Guide To …”
