Will the arlo base station connect to internet wirelessly? I do not have a router with ethernet plug in. It's all wireless. Any help would be great.
The base station requires that the connection is made via cable to either a router, extender or AP. If you have no access to either it will not work and the recommended way is direct connection to router.
