Base station can't be used for arlo pro 2? WiFi light does not turn on
our company buy a arlo pro 2 with station in USA, I want to ask that it could be used in china ? because we can't connect to WIFI from station to APP ,the middle light is closed forever.
If the Internet (middle) LED is off, the base isn't even connecting to your router. Try a different port on the router as well as a different Ethernet cable. Sometimes rebooting the router helps.
