Base Station offline after leaving taking out router
The base station VMB4000r3 is not staying online after I leave and the cameras are armed with the geofence. The cameras are at a second home and will work all weekend but once I leave after sometime it takes everything offline. It is also taking out the router and disconnecting other devices such as wemo. Any idea what would cause this?
Your presence doesn't matter. What does matter is power and Internet connection remaining active. Then your phone needs Internet access that doesn't block Arlo. You should be able to connect from anywhere in the world.
