Base Station Yellow light indicator for Cameras. Sometimes go green and back to yellow flash?
  • 1 Reply
  • 1063 Views
Steve_Koch
My yellow light for cameras flashes on the base station wether the cameras are on or not and are fully charged. It sometimes then turns green but will go back to the yellow flash. Cause? Fix?
That sounds like a very weak signal between the base and cameras. To test, move the cameras closer to the base. House construction, distance between the base and cameras, objects on and in the walls, nearby 2.4GHz wireless interference, etc. can all cause this so testing is needed.
  • 1 Reply
  • 1064 Views
