Base Station Not Showing up During Setup
Hi,
When i try to connect my base station and set it up, it says thats it's taking too long to find it. When I begin the internet connection is fine, but during the setup proces it starts to blink amber. I have tried 15 times both from my phone and from a computer.
It worked once, but then it kept saying that the base was offline and I had to remove the device from my account so I could try again.
Do a factory reset of the base ( hold in reset for about 10 sec till the leds flash amber ) and then try again
