I finally got everything working again after the new UI App update. The only thing that I have a problem with now is I’m missing the Away or Home notification that use to pop up. I miss it because I could at a glance see that the system Armed/Disarmed.
DCrusher1,
Are you using an Arrive/Leave Automation? If so, you should be able to add a notification rule to the automation to be sent when triggered. Check your automation rules and make sure you have the "Send a Notification" action added.
DCrusher1,
WOW!!! Very simple Thank You.
The setup is starting to work like SmartThings. I love it.
Thank You.
