  • 7 Antworten
  • 2567 Aufrufe
  • 2 in Unterhaltung
Thanoskat
Habe vms 4130 kann aber in der App nicht gefunden werden. Oranges Blinklicht andauernd
7 ANTWORTEN 7
This means there is a connection error.
Have you checked that the ethernet cable is securely connected to both the router and the base station?
If so, I suggest trying a different cable, and also a different port in the router.
Thanoskat
I already tried another cable. I have the same problem. Connection is established because I can see than one the router. But on the app the hub-station doesn’t appear
You tried "add device" to add the base to the account?
Note you can do this either with the app or from a PC (browse to my.arlo.com).
Thanoskat
Yes I did
@Thanoskat wrote:
Yes I did
From both the app and a PC browser?
Thanoskat
The station does not get an ip and doesn’t connect. Orange light is blinking. Even after pressing reset over 10 sec.
Ok, that is different from what you said before.
This could be a failed ethernet cable, or a loose connector on the connection between the base and the router.  If you have another LAN port on the router, try connecting the cable to that port.
Hopefully this is not a failed ethernet port on the base, as that would be unrepairable.
