Arlo pro2 base station offline frequently
  • 2 Replies
  • 894 Views
RoopeshNair
VMB4000R3 - base station Arlo pro2.
The base station frequently goes offline. All lights green but the status is offline and cameras offline as well. I have to hard reset using paper clip and it works sometimes after repeated attempts. Can you please help
slompochomp
Luminary
Luminary
So all lights are Green?
What do the LEDs on my Arlo or Arlo Pro base station mean?
So where is it saying that it is offline ? Is it just the camreas that are offline or the base station it self ?
If it's the camreas maybe they have poor signal strength.
make sure the base station is set up in a high location where there are less obstructions for the WiFi signal.
If it is the base station maybe your modem or router is the issue.
Check the modem dBmV levels and moniter your modem connection.
How do I view the downstream and upstream power levels of my cable modem or modem router?
Moniter your router and see if that is dropping the connection.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
The green LEDs but offline has proven elusive to understand. Try rebooting both your router and base, in that order. Log out of the app and back in. Try a browser. Does anything help?
  • 2 Replies
  • 895 Views
