Arlo pro camera on arlo pro base station
Does the arlo pro cameras work toghether with the arlo pro 2 base station?
Yes... the Arlo cameras ( Arlo, Arlo Pro, Arlo Pro2 ) will all work with any of the base units ( Arlo, Arlo Pro, Arlo Pro2 )
@TomMac Is there a benefit to using the Arlo Pro2 specific base station? Or would I be able to use all the new features of the Pro2 cameras on my existing Pro basic base station? Trying to decide if it's worth a complete upgrade or if I could get the same results by adding on one camera of the Pro2 version. Thank you!
Thanks a lot.
Thonking of adding two cameras to my arlo pro 2 system but dont need to be that good quality so I thought about two arlo pro cameras instead of the arlo pro 2 cameras, that btw are great. 🙂
Yes, just add the camera if there is no need to expand you coverage area.
The Pro base and the Pro2 base are,TBMK, the same... may be some slight differences internally but they are the same to the user and makes no diff which one you use
