Arlo pro 2 siren mode
Did Arlo remove The siren mode feature or does the Arlo pro 2 not support it ? I went on base station and tried to edit it but the option for siren isn’t there
For the last four months the VMB4000 Base siren device was no longer visible when using the arlo mobile app.
A few months ago it was still visible using the web portal although you were unable to alter the device name as doing so would also alter the base name also.
Not sure if the new app experiment works the same in this regard.
What about vmb3500 base ?
Only the vmb4000 has the siren, the 4500 has one but they forgot to design it with holes so you could hear it.
There is conflicting information about the vmb4540 having a siren but unable to determine due to a lack of tech documentation from arlo.
This document so no siren.
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
