Arlo pro 2 just stopped working wont charge.
  • 1 Reply
  • 581 Views
enhicks
It my camera covered under warranty? One of the cameras just stopped working wont charge. Its a little over a year old.
Dannybear
Do you know if it is the battery that will not charge or is it the camera that’s faulty.
Try a fully charged battery from a working camera or remove the battery and power the camera from the arlo supplied charger and cable to see if it will work ok.
If you have a subscription plan you can seek arlo support via the arlo app support feature to see if warranty is still valid.
  • 1 Reply
  • 582 Views
