Arlo pro 2 charging port cap not staying shut
Plastic cap that covers the USB on camera not staying shut. What to do?
I had one camera that did this after using a solar panel that was then removed. I had to work at it a bit but was able to get the cap pushed in properly after some concentrated effort aimed at pushing it in (think wiggling your finger while pushing).
you can contact Arlo support if a warranty issue or if not use a white piece of elec tape over after closing
