Arlo pro 2 battery charged but won’t detect
I have 4 cameras arlo pro 2. One of the cameras the battery is fully charged but the blue light will flash. Then it will go off. Every once in awhile it will record. Anything I can do to fix it? Battery is charged internet is good.
When does the blue LED flash? It should only come on when the battery is first installed or after pressing the sync button. A few folks havementioned that they have needed to put a small wad of paper between the battery and camera door to force the battery into contact with the camera. If that's the case, open a case with support for a hardware problem.
