Arlo pro 2 automation not working take 2
  • 5 Replies
  • 346 Views
Foshizzle
Still can’t get automations to work.
5 REPLIES 5
While I tend to doubt it makes a difference, try renaming one of your schedules other than Home (just thinking the same name may cause the software to be confused).
Can you give some specifics on what exactly is failing?
I am seeing that your Leave automation was disabled when you posted.  Were you home when you took those screen shots?
Foshizzle
Yes I was home.
Foshizzle
Some mornings it doesn’t go to standby even though I am at home.
One thing that is wrong is that your 9pm schedule is disabling "Arrive".  That won't work, because the "Arm Home" mode switch will reset which automations are enabled.
Try removing the geofencing automations altogether, and see if straight scheduling works.
  • 5 Replies
  • 347 Views
