Arlo pro 2 Camera Intermittently blinking
  • 1 Reply
  • 860 Views
Onurinal
One of My Arlo cameras (which is facing my baby crib) intermittently blinks and wakes her up!
here is how it’s setup
(there is no firmware update)
-it’s connected to power
-activity zone is set
-brightness is set to high
Any idea would be appreciated
thanks
DannyBearAgain
Which camera LEDs are flashing? The blue one or the red ones.
The blue led turns on when the battery is fully charged and can be turned off in the camera settings. It will flash though when it gets polled by the base station. If this is causing an issue then place a thick sticker over the blue led location.
If you’re getting the red LEDs causing the issue then this can be disabled by turning off the night vision in the camera settings. This will give you a very dark view though but could be compensated by using a night light.
  • 1 Reply
  • 861 Views
