We currently have 8, 720 cameras set up on an Arlo pro (rectangle router). We just bought a Arlo pro 2 with 3, 1080 cameras with a round router. Can we transfer the 720 cameras over to the new router using our same account? Or do we add 2 of the 1080, to our current system. Thank you
You can use your original wire free cameras on the 2nd base station, you will need to remove them from Settings > My Devices & sync to the new base.
