Arlo Pro2 wired instead of battery powered
Just had a new house built and my husband had it wired out front for a camera. We also have the Echo Show and I had read the Arlo Pro was battery only which my husband didn't want. So can this new Arlo Pro2 be wired and not do the battery? I would love to win one and joined here to post hope this goes to the right thread.
Arlo Pro 2 can be permanently powered outdoors with the Outdoor Power Adapter VMA4700 but that's not much help for a pre-wired location.
https://www.amazon.com/Arlo-NETGEAR-Outdoor-Power-Adapter/dp/B071K62DZV
Arlo Pro II can be continuously powered indoors using the supplied indoor power adapter. At this time we do not support continuous outdoor use with an outdoor power adapter.
I'm confused, isn't one of the advatages of pro 2 is that it can be AC powered for outdoors? It looks like it's being advertised this way.
skysigns wrote:I'm confused, isn't one of the advatages of pro 2 is that it can be AC powered for outdoors? It looks like it's being advertised this way.
Yeah........long story, for Netgear to tell us at some point. We’re all waiting for it.
Huh ?
Can you please explain.
This has me very confused as it lists the VMA4700
https://kb.arlo.com/000049386/How-does-the-Look-Back-feature-work-on-my-Arlo-Pro-2-camera
Hula_Rock wrote:Huh ?
referring to one other "by design" flaw, a camera (experienced it with the original Arlo, don't know about the Pro) can be turned OFF but it will still record when included in a cross recording rule.
Seems the recurring answer by Netgear to unexplainable oddities.
Funny you say that...... I just experienced that situation. 2 pro2's, I turn one off, had cross-recording rules set. to my surprise the turned off camera recorded.....
Hula_Rock wrote:Funny you say that...... I just experienced that situation. 2 pro2's, I turn one off, had cross-recording rules set. to my surprise the turned off camera recorded.....
"By design"
steve_t wrote:Arlo Pro 2 can be permanently powered outdoors with the Outdoor Power Adapter VMA4700 but that's not much help for a pre-wired location.
Steve:Amazon Canada has removed the Netgear Arlo outdoor power adapter from their available products. Apparently notices were sent out to current owners about potential problem with its weatherproofing, as it may be possible for water to enter camera through its connector. That is why Arlo is currently not supporting the adapter’s use outdoor.
Likely will come up with a replacement product, but no word as to its ETA.
So yet another issue thread with a statement from arlo but no action.
Without a outdoor power cable the Pro 2 cannot use CVR or motion zones two of the main reasons for upgrading.
Its' called misrepresentation.
So they sell you a product that you believe by the sales pitch to be able to do one thing, but find out later that actually it doesnt, or you can only use a subset of it's capability and has some faults with no fix or that the product is over-priced in comparison to traditional IP cameras, is inferior quality and have a support channel and engineering channel that doesn't know their left from their right or have an effective management structure.
Note they will No Doubt remove your post most of mine we're, so they are happy to watch and delete factual negative posts but not actually solving issues.
Ensure you make your voices heard on their and partner social media sites.
So I now have two covers and two power cables all original Arlo not fit for use.
