Arlo Pro2 vs Pro1
What features are in a Pro2 system vs a Pro1?
I have heard of night vision camera problems in the 2 - shoould I just stick with the 1 version?
Stick with the Pro 1..... Best advice you'll get from this forum......
The biggest "feature" for me is the 3-second pre-buffer on the Pro2 when plugged into an outlet. Although this powered configuration is recommended to be used indoors (with the included power cable) at the moment, Netgear is actively working on a replacement outdoor power cable so the Pro2 can be placed outdoors powered by AC.
