Arlo Pro2 does Not Connect
  • 1661 Views
DocMH
I cannot connect Arlo Pro 2 with base. Blue Lampl blinks and Green at base. Connection Not possible. Camera cannot be found.
Old Arlo Camera is Working and Connects immediately.
I have tried Many Times... Support does Not answer.
raydu
After a few rainy days, one camera won't connect and sync with several tries with arlo support.
Support agrees to send a new camera and I have to pay return shipping for the bad camera.
I only use arlo pro 2 for 4 months and it seems that quality is an issue with this product.
DocMH
Support could help
LAN cable out, switch off the base, restart, camera battery out and back in. Then make new connection base with camera. Restart, only then plug in LAN again. Running.
So gehts bei Verbindungsproblemen
LAN-Kabel raus, Basis ausschalten, neu starten, Kamera Akku raus und wieder rein. Dann neue Verbindung Basis mit Kamera machen. Neustart, erst dann LAN wieder anstecken. Läuft.
DocMH
Support could help
  • 1661 Views
