The Nest camera constantly records and marks where activities have occurred.
With the Arlo Pro 2 it seems to only record when there is motion detected.
Is it possible to have the Arlo Pro 2 camera record 24x7?
If it can record 24x7, will it do so for both cameras and save for the 7 days?
Yes, with the additional CVR plan/subscription and the Arlo Pro 2 under AC power, you can record 24/7. Motion and audio triggered recordings will be added to your library. When you view your CVR timeline, there are green or blue marks to indicate motion or audio triggered events
To be able to record 24/7 I believe you have to purchase that option through the subscription plans. Check them out at
https://www.arlo.com/en-us/products/subscription-plans.aspx
Brian
Thanks for the info.
$100/year per camera is a bit too much.
