Arlo Pro2- Device Offline warning via arlo app
İs it possible to receive a warning via arlo app when your arlo pro2 base station is
1- offline / power shortage or,
2- not connected to internet
No there is no such feature.
Can't Netgear add this as a feature?
That would be very useful.
They should be able to do that quite easily. My Smartthings system notifies if my hub has lost power and/or it has lost interned connection.
Place this suggestion in the Idea Exchange and hopefully it will get enough Kudos for the engineers to implement it.
Also read some of the ideas on the Idea Exchange and kudo any that you would like to see, especially if you see other suggestions about your suggestion.
Brian
