Two questions -
1) Is the base station for Arlo, Arlo Pro and Arlo Pro2 the same
2) If I want to extend the range of my Arlo Pro2 Cameras ( I have 5 and two of the further ones barely pick up the signal) can I add another base station as I have 4 routers in my house?
Thanks in advance,
All cameras are compatible with all bases.
The original base has no siren or local USB storage.
Yes, you can install a second base closer to the distant cameras.
Just add it as a device using your existing app.
Thanks Streak
