Arlo Pro With 2 Base Stations On One Account
I have a system at each house. My app only allows 5 cameras, but I have two different bases. Why can't they all be on the same app. I bought two systems means I should be able to use all the cameras.
One account can only support 5 cameras total. If you want to exceed that, upgrade your subscription or use a second account for the second system and use Settings, Grant Access from the second account to the first so everything shows in one login. Of course, each account can still only have 5 cameras.
