Arlo Pro / Pro2 - Can you use a 3rd party motion sensor to make the camera record with SmartThings?
I have this system integrated with SmartThings. Can you use a 3rd party motion sensor to make the camera record.? The camera itself only has 23’ detection range. This isn’t far enough.
I have my Arlo system Integrated with Smartthings. I have the regular Smartthings Motion Sensors mounted under the eaves of my home to start the outside cameras recording earlier than the cameras normally would record by themselves. I set up Custom rules that when the system is either in the Away or Night Modes to record video if motion is detected by the sensors. I also have created a custom Routine to only arm the Front Porch camera when I am home and waiting for the Mailman or a delivery. The motion sensors detect them arriving and start the camera recording video.
I don't know of any truly outdoor sensors that are weatherproof, so depending on what you wish to detect, this might not work.
Brian
Thanks Brian! Can you set the camera to record within the motion sensor setup or did this require special IFFT programming within the SmartThings IDE.? I am not a programmer. Thanks. David B
I am not sure quite what you are asking me, but I think the answer is no.
You don't need to know how to program of use IFTTT.
Firstly, You need to have the Smartthings Mode setup in the Arlo IDE or app.
Secondly, Smartthings acts like a switch to Activate, (set the camera to standby, so to speak, ready to record), and Disarm the camera so that motion or sound don't trigger. That is where the Routines come in. Modify your Smartthings Routines to activate whatever cameras you wish to activate for that Routine. Examples: Goodbye Routine will probably have all the cameras set to active. The Good Night Routine will probably have only the outside cameras activated. So now the Routines are acting as a switch for the cameras you have chosen.
Thirdly, are you familiar with how to create Custom Rules? If not let me know, but if you do, create a custom rule for that sensor. In that Rule choose which camera/cameras you wish to record when motion is detected, in which modes you want this sensor to start the recording and what notifications you wish Smartthings or Arlo to send you.
You can also create other Routines, such as Mail, that will only activate the camera nearest your mailbox while you are home and use the outside motion detector to start the recording when it senses motion as the mailman walks across the yard, etc.
Just about any Smartthing sensor has the ability to start a camera to record.
Brian
Also, if camera “A” starts recording can it trigger camera “B” to start recording as well?
Since Smartthings is now in control it will set the cameras to do nothing. That is normal.
Can you add a Routine and name it Test?
Click on the gear icon at the top of the Routine.
On the next page select the two cameras where it says Turn on these lights or switches.
set Smart Home Monitor to Disarmed
Hit Save.
Click on this Routine and go to Things and see if both cameras are Active. They should be.
Now go to your home page and click where it says Everything OK
On the next page click on the gear icon at the top right of the page. Here are your Rules.
Select Custom
At the bottom of the next page click on New Monitoring Rule
On the next page select Motion Sensor and for now select the motion sensor you want to use as a test.Click on Next at the top of the page.
On the next page select the Text and Push Notifications for this Rule.
When Finished with that, come back to this page and at the bottom of the page, select both cameras.
On the next page, click on the Edit Rule Name slider and then above that. Enter Motion Test or any name you wish.
Click on save.
Now back out and select the Test Routine to turn the cameras to Active and walk past the sensor.
To turn the test off, just edit the Good Morning Routine to turn off the two cameras.
Once you get the hang of it you will think of all kinds of things to make custom rules about.
Enough for this post, let me know when you have done that and ask me any questions about any problems that you have.
Brian
OK, glad to know that you know how to do all this in Smartthings.
I currently have two Smartthings Motion Sensors outside under the eave of my house that I use to trigger the cameras to record video, but only if I have set the cameras to Active by running a Routine to do this first. So yes, it can be done. Arlo natively won't allow you to add any third party sensors, but as long as Smartthings recognizes the sensor, and is in reach of your hub and out of the weather it can be done. 50 feet might be stretching it a little though. Read the Smartthings community forum to see if others have found an outdoor sensor, (assuming your cameras are outdoors, of course), that have that kind of range and are weatherproof.
Brian
Do you have a motion sensor yet? Since you have the range this should be easy. If you start with a Smartthings motion sensor first, later you might find one that works better, but I think they are pretty good. There are quite a few third party motion sensors out there, but you will have to know how to use custom device handlers to set them up and use them.
There is nothing in the motion sensor setup that will do this for you, regardless of the sensor used. . Once the motion sensor is added to Smartthings, you must tell it what to do.
You can just write a Custom Rule that tells the camera to record when motion is detected. If the camera has started recording, the motion sensor in the camera will do nothing, but if there is motion and the sensor doesn't fire, the motion sensors in the cameras will fire and start recording.
In May Arlo is releasing the outdoor motion sensor with a strong light. If you can wait that long and you purchase one of them, they will work natively with Arlo and I hope with Smartthings.
Brian
In the Smartthings app. I'll show that again.
Go to your Smartthings app home page and click where it says Everything OK
Select Custom
Click on save.
Don't try this until you actually have a motion sensor.
If I am not mistaken, Zigbee has a better range than Zwave, but I am not sure. I will do a little research but it will be tomorrow before I get back to you.
Brian
I have done a little research and here is what Ihave come up with so far. 50 feet is quite a distance away from the Smartthings hub for any motion sensor. The only way to see if your signal will reach that far is to try.
If the distance is too far to work, you can probably make some sort of weatherproof housing to put the sensor in, like a fake birdhouse.
Secondly, If your wifi reaches your garage, you could simply mount a camera there. If not, you might be able to use a range extender in your house as close to the garage as possible. If that doesn't work, then maybe adding a second range extender and a second base unit in the garage.
By far, if you can get it t work, the external motion sensor is the cheapest route.
I recommend the Smartthings sensor as it is pretty good, fast and you don't have to use custom Device handlers. It is a zigbee device so it will probably have a little better range than a zwave one.
Both Zigbee and Zwave devices work as a mesh. People often use the Smartthings wall outlet plug that plugs into a wall outlet to extend the mesh range. You do not need to plug any devices into it if you don't want to, but it does improve the range of the Smartthings sensors.
Brian
You are welcome.
When you start really getting into Smartthings you will go broke purchasing all the things you think you need, LOL.
A couple of other things I do with Smartthings:
Since almost all the sensors that I use with Smartthings report temperature, once I determine if it is reporting the correct temperature or close to it, I wrote some custom rules in Smartthings to send me notifications if the temperature gets too hot and I use that sensor to trigger the closest cameras to record what is going on. I use water leak sensors to check for water leaks, and while I can't trigger any cameras with these sensors, I can look at the nearest camera's live view to see what is going. And of course you can trigger lights to go on and off, etc.
Brian
