Showing results forÂ
Arlo Pro Model VMC4030 will not turn on at all
The unit will not turn on at all. I replaced the battery and, nothing. I Check the battery with another camera and the battery and camera works fine. Tried a different battery and, nothing. No blue flashing lights, no any kind of lights. Any suggestions are appreciated. Thanks Community 😊
A bit confusing as you posted under model of the Arlo Q ( which doesn't have a battery )
But the Pro does...
Try the original ac adapter with the battery out and see if the led flashes blue when plugged in and/or runs
