Arlo Pro - How can we revoke access to the app that had previously been given?
It depends on what you mean. If you used Settings, Grant Access, simply delete the user in question. If you mean you set up the app on a second phone, either delete the app, which would require the password to be retyped, or change your password if the person with the second phone knows your master passowrd.
