I have Arlo Pro cameras and just today my geofencing is not working. I am home and the app says that I am "In Zone", yet it is saying that the system is armed. I also noticed that Arlo Smart is not filtering, and it is allowing all motion for one of my cameras to come through when it should only be People. Is there a bug? Any help would be appreciated. I already tried unplugging the base station and restarting. Thanks!
Can you escalate this to the Dev team, the latest batch of firmware update (or App?) broke geofencing.
For the last few days the system is not disarming the system when i get close to home. I don't not get the alert on my phone stating I entered the zone. I get the alert when I leave and is will arm the system if I disarmed the system.
Yup, count me in for having this issue as well since the last base station update. The app shows both phones as being "In Zone", but won't disarm the system.
Are others having this issue? What is the fix?
I am having the same issue with the latest app update. When I arrive home, the geo-fencing still has me away and I need to manually go into the app and disarm the cameras. I can then go and select geo-fencing to return to my usual geo-fencing and the app will then see me at home. Geo-fencing when I return home is useless but when I leave home works fine. Please fix.
Mines not updating to Home Mode either!
OMG HERE WE GO AGAIN!
What is it with Arlo and GeoFencing & whatever or whomever is in charge of it? The incompetence of this (product/people who are tasked with making it work) is on a whole other level!
the recent update to 2.7.9 didnt help with the geofencing issue that i have. i am using ios 12.2 on an iphone 8. geofencing activates fine when i leave the zone, but it doesnt disarm when i return. when i check the map it shows that i am located right on my base station. tried all of the suggested fixes, nada.
i really like my arlo pro until this happened, hopefully someone in some upper tier tech support and fix this problem soon. if not i dont think i can continue to recommend this product to friends.
@BrianP53 wrote:
Since the update of 20 May 2019 my Arlo will not acknowledge geofencing home mode. It will acknowledge geofencing away mode.
Do you mean it is not sending home/away alerts?
Or is an app not showing the correct status?
Just another user
Another one:
Arlo Pro Geofencing no longer working - Arlo Communities
Just another user
I too have noticed this. The recent update 20 May 2019, version 2.7.9 (90) did not fix this issue. What is even more bizarre is I get the notification on my phone that I am entering the geofenced area when I get inside the bubble. So clearly the app sees that I am "home" yet doesn't go into to Home mode. If I manually set the mode to Disarmed or Armed, and then put it back to Geofenced, then it recognizes that I'm inside the geozone, and goes in to Home mode. I'm on iOS 12.3 on a iPhoneX.
See also:
Arlo 2 geofencing - Arlo Communities
Just another user
Two more:
Just another user
Same issue. Started happening about 1,5 week ago.
Arms when i leave home, but not disarming when i get back home.
Not working for me either after installing 2.7.9. Same as before the update. I am using 2 iPhone 7's running the current IOS. My phone is the main phone with the Arlo account. My wife's is an authorized user. When we are both at home, Geofencing shows the location on its map, and the Arlo locator is showing inside the zone (small zone), and it is flashing. My phone receives notifications for both phones. Yesterday we went out together for a ride. When we left the zone, my phone received a notification that I had left the zone, but nothing for my wife's phone. When it works properly I receive a notification for hers also. I opened my Arlo app on my phone, and it showed I had left the zone but showed my wife was still in the zone--NOT TRUE--. Also, when I looked at the Arlo zone map, it did not show any Arlo locator in the zone. So although it says my wife's phone is at home, and that she has not left the zone, there is no locator in the zone. This is doing the same thing as before. When we returned home, I received a notification that I was in the zone. Both phones showed as being in the zone. Arlo should have become armed when we both left the zone, but it stayed Disarmed. Something changed with the Arlo update a few generations back. It had worked fine for at least 6 months, maybe longer.
