So Arlo Pro 2 has 1080p resolution, that's great but the real problem with Arlo Pro is the lag time. I would appreciate it if Arlo Pro 2 fixes that problem. Another thing I would appreciate a lot is incorporating motion detector lights with the camera and equipping them with a reasonably priced solar panel. Your solar panel is incredibly expensive for $80. I bought a solar powered motion detector lights for less that half the price of your solar panel. A little bit more flexibility with scheduling mode will be good too.
The lag time is eliminated if AC powered. That's the 3 second look back feature.
