Hi everybody,
I have 4 of the Arlo Pro cameras, relatively pleased with them, had them for several years now, perform as well as expected. Was thinking of buying one Alro Pro 2 add on camera. Is it worth it? Best Buy-Arlo Pro-$150, Best Buy-Arlo Pro 2-$220.
What do you think? Thanks.
I have both, and don't think there is much difference if on battery. The Pro2 has a wider FOV and a few more options if plugged into ac all the time ( look at the tech specs in info , top of page )
I actually find the Pro model to be better with night vision.
