Arlo Pro 2 wont connect to HUB?
Hi all,
After some help with my Arlo Pro 2 camera - it used to work fine but for the life of me I cant get it to connect any more.
I have other Arlo cams working fine on the hub.
Here is what I have - Arlo Ultra Hub, with 1 Arlo Ultra cam, 3 Arlo Pro cam's and an Arlo Light which all working fine.
I am on a "premiere"plan that came with the Ultra hub/cam.
When trying to connect the Pro 3 Cam I do the normal process of removing battery starting the add cam from the app - I when told insert the battery hit the sync button on the cam - the cam blue light starts to blink and the app tries to find the camera - but it doesn't find it - after about 20-30sec's of blue light blinking the blinking gets a little faster for about 10 sec then stops.
I have tried this process many many times now - even tried powering off the hub - restarting it again - but still no joy.
This Pro 2 cam has worked fine in the past so not sure if it is related going to newer Ultra HUB ?
Any suggestions appreciated
Cheers Frosty
Have you tried to press the sync button on the back of the hub, then press the pro 3 sync button?
Only way I could get the ArloPro2 cam to be recognised was to reset the hub to factory and start again (with all my other cams)
All going ok now
Cheers
