Arlo Pro 2 went offline and I just recharged. Failed to turn camera ON: (2059).
Hi I have arlo pro 2 ,went off line and I just recharge. Failed to turn camera ON: (2059).
What happens if you remove and then reinsert the battery?
If you suspect that the battery isn't charging, then try this: https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Nothing still not working
If you tried all the steps in the kb article, then you probably should contact support: https://www.arlo.com/en-us/support/contact.aspx
