I cannot adjust adjust the record time on any of my devices. The edit pencil or arrow is not there on the Armed mode.
It is only on the scheduled mode. What do I have to do to be able to edit this?
There is no issue with using previous app version so you will need to wait for the next version to see if it get fixed.
Of interest if you create a custom mode do you have the same limitations?
Have you tried the web client as well as the app on a different device?
