Arlo Pro 2 system subscription plan
  • 1 Reply
  • 1269 Views
Rammohammad
I live in Kuwait and I have 8 arlo pro 2 cameras with 2 base stations, However my subscrption plan only allows for 5 cameras. So I have 3 idle ones.
I tried to upgrad my plan but I have no option to do so>
I desparetley need to upgrade in order to include the 3 additional cameras.
regards.
There's an FAQ here that details what countries have the additional subscription capabilites. Lots of countries do not. Since you can't upgrade, create a second account using a second email address. Claim one base on each account and sync appropriate cameras to each base. Then use Settings, Grant Access from one account to the other with the additonal access privileges enabled. After following the emailed directions carefully, you will be able to see and (mostly) manipulate all cameras with the one account that was granted access. There may be a few things that will need you to actually log into the second account for complete control - see te FAQ here on what privileges each setting allows.
  • 1 Reply
  • 1270 Views
