- Email to a Friend
Hi,
I have notice lately that my Arlo pro 2 camera's are still recording, even when i have selected Disarmed mode.
Also my Gmt uk time, seems an hour out, which is affecting my scheduled set times.
Thanks,
Mark
- Email to a Friend
Have you been in contact with support?
They will likely ask you to reboot everything, check your base time zone.
If you already done so then sounds like a server issue that only support can escalate.
- Email to a Friend
I’m having the same issue with cameras still recording when disarmed. Did you get a solution?
- Email to a Friend
Afraid not, thought the updated app would have resolved this.
- Email to a Friend
I just restarted both of my base stations and the issue seems to have resolved itself (the ‘away’ setting came on as default after the restart and when I selected ‘home’ / geofencing I got two messages from each base station, one confirming ‘away’ followed by one for ‘home’). If if recurs I’ll let you know.
