Arlo Pro 2 slightly wider field of view vs Pro side by side
Pro2
ProSide by side Arlo Pro 2 and It looks to have a slightly wider angle. Also seems when using the app/website the default photo saves as a 720p?
Cool comparison. Pro 2 is a little bit wider in FOV, a little bit sharper, and a little bit better in the lower light areas
