Arlo Pro 2 : several bases in the same home
I have a built concrete house which has 3 floors.
I understood that I would have to put a base connected to my box on the ground floor and to put another base on the third floor for example so all the cameras could be connected in each floor….. because a camera on the third floor could have difficulties to communicate with the base at the ground floor, due to distance and the wall thickness.
And so during the installation I have to pair the two bases , then to pair the cameras at each base.
Is that what you have to do?
Before buying 2 kits with each 2 cameras, I prefer to check.
Thank you for your reply.
Best regards
You don't pair the bases - they simply need to connect to your network via an Ethernet cable. Yes, once the bases are installed, you would pair the appropriate cameras to the appropriate base.
