Arlo Pro 2 schedule mode not working correctly as it is armed all day and not following schedule
I've had 4 cameras set up on a scheduled mode that I created months ago. Suddenly the cameras stay on all day, even though they are set to go on at 8pm, off at 11:49pm. Then back on from 12am to 6:30am.
I have made no changes to how I set it up months ago. Why is this happening?
Thank you for any help.
I have had a similar experience using the schedule. It would work ok during the daytime mode but when it got to the evening mode it would not change over. The mode status would not show the evening as selected, just shows blank with the clock icon.
I had to delete the evening mode and rebuild it again for it to be recognised in the schedule again. Now it shows correctly in the mode status when the changeover happens.
Hope this helps.
Thank you. I will try that. Appreciate your help.
