Arlo Pro 2 question - local storage
  • 1 Reply
  • 772 Views
bruzogiri
On the Arlo website the Pro and Pro 2 both appear to have local storage by adding a USB drive to the base station.
I can't see whether or not the Arlo Pro 3 is due to still have this feature, does anyone know?
The base will save recordings from all cameras that are connected to it.
The ability to access/playback those recordings depends on the hub model you own.  There's a VMBxxxx label on the base that will tell you the model.
Also, let us know if you are thinking about dropping the subscription, as there are limitations you should know about.
  • 1 Reply
  • 773 Views
