Arlo Pro 2 parts
  • 1 Reply
  • 419 Views
Dam7
I need to replace the power cord that goes from the plug in wall charger to the camera to charge the battery . The parts listed on line don’t show a replacement. Is there
Most of the Pro/Pro 2 accessories are no longer sold by Arlo.
The cable is a standard microUSB cable - the problem is that many stock microUSB have too big a sheathing to fit into the socket.  But if you have some of these cables at home, there is no harm in trying them.
There are third-party options that claim to be compatible with the Pro 2 if you look at Amazon and other store fronts.  You can just use the cable, and save the charger for later use if you like.
If the camera normally runs just on battery, then you can also get a stand-alone charging station.  Arlo is still selling those:
There are cheaper third party ones out there.  I don't use them, so I'm not recommending one, just letting you know they are out there.
  • 1 Reply
  • 420 Views
