Arlo Pro 2 mount and power adapter accessories?
I have 2 questions.......
1. I have the Arlo Pro system and I also purchased skins, additional security mounts and power adapters. Will these accessories fit the Pro 2 version cameras???
2. When will you (Netgear) run the same giveaway promotion in Canada??? Why did we get left out of this promotion ???
Opps...thats 3 questions
The Pro and PRO2 are the same size/shape...all the accessories should function with both cams
( only possible exception may be the outdoor weatherproof power supply, there's a ? as to this being changed for some reason unknown )
I’m using the outdoor adapter on a Pro 2 and works real good 🙂
Not so sure as just swapped and in the field on view can see the rim of the arlo cover, same on both cameras was not an issue on Pro 1
