Arlo Pro 2 motion detection resets to 80%
I have changed the percentage slider on the Motion Detection Test to 95% on all my four cameras. But every now and then (may be like once in 3 weeks), when I suspect fewer recordings, I go and check the settings and I see that detection has gone back to 80%. I have to change it again to 95% and click the check mark to save it again. I have been doing this regularly. Am I the only one experiencing this issue? I don't see any other posts about this. Please help.
There have been FW updates lately in the Pro and Pro2 cams.... it may be resetting to default at that time ( which is 80% IIRC )
The Motion Detection Test just gives you a number to insert into your modes/rules. A global setting isn't a good idea since you may well need modes with rules that have different sensitivity settings for different times of the day.
