Arlo Pro 2 does not record motion to library or sends email notifications
  • 1 Reply
  • 572 Views
stevetynant
I have 3 Arlos at the moment - 2 Arlo Pro 2s on mains power and 1 Arlo HD on Battery. Up until a few weeks ago all worked perfectly now however for some reason one of the Arlo Pro 2s does not record to my library or send email notifications though works perfectly in Live Mode? The Other 2 Arlos are working as expected - I've checked the control panels and all look to be set up identically to each other so I'm unsure what has suddenly changed to cause this - obviously I'm not sure how to fix it either so any suggestions would be most gratefully received Thanks Steve
Dannybear
You mentioned that the control panels look identical but have you checked the mode rules where you can choose the recordings and notifications?
  • 1 Reply
  • 573 Views
