							Arlo Pro 2 detecting every other minute or so
I have one camera driving me crazy. It continually notifies of motion detected every other minute or so. Have moved twice & have motion turned down to 1%. At our wits end with this continually going off. Every recording a minute apart shows absolutely no motion. Now what besides sending it back for replacement?
						You could try power cycling the base station.
You can also try removing the camera battery for 10sec to reset it.
Where are you setting the sensitivity, should be in the camera rules for the active mode selected.
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy995
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
