Arlo Pro 2 costco
Any thoughts when the Arlo Pro 2 will be available from Costco? Prior posts have suggested looking on the Netgeat site for "places to buy it" but this typically doesn't list Costco as a choice even for the Arlo Pro (which Costco sells). Curious timeline we're looking at for both a starter system (3 cam + base) as well as the add-on (2 camera packs) - akin to the Arlo Pro packages.
Hey there,
I contacted Costco directly when I was returning my Arlo Pro as I wanted to buy the AP2 from them, they said they have no idea, it's all up to the buyers.
I ended up buying AP2 from Best Buy and returned them 10 days later due to poor night vision, sensitivity issues and dropping offline, YMMV
Good luck
Rick
