Arlo Pro 2 cord
Where can you get a good replacement cord for the Arlo 2 ?
Are they trying to phase out this Camera?
They stopped making it in 2019, so yes. It is on the EoL list (going EoL on 1 Jan 2025). While the cameras are expected to work after that, accessories (notably Arlo branded dbatteries) have disappeared.
It is just a standard microUSB cable. The challenge is getting it to end of the cable to fit into the recessed charging port. Sometimes if you are careful you can trim off some plastic on the connector.
Another option is to purchase a stand-alone charger. Arlo's is out of stock, but there are some third party ones that say they are compatible.
